Plz, I really need the Mk3 width
Postby todoterreno » Sun Jul 16, 2017 8:31 am
Sorry, I wanna go for my first van this week , a 1997 SWB Transit , but i need to know the total width with folded mirrors , my garage door's 87 inches / 2200mm and I know Transit width without mirros (chassis width) is 1972mm , and about 2500 with mirrors.
I'm not an expert driver, do you think i could get it in okay?
todoterreno
Re: Plz, I really need the Mk3 width
Postby ricc » Sun Jul 16, 2017 2:54 pm
once its in is there room to open the door. dont forget to check height.
putting a van in a garage is a bit of a novel concept ... where you going to keep all the stuff that lives in the garage?
i built our garage 30 odd years ago ... never ever had a vehicle in it.
ricc
Postby todoterreno » Sun Jul 16, 2017 8:27 pm
Thank u, but there is no walls in the garage, just 4 concrete columns, so i just need to cross the garage gate (which is 2200mm wide), that's why i need someone with a metric tape to measure the width with folded mirrors. I really want to buy it!
todoterreno
Postby Altransit » Sun Jul 16, 2017 8:41 pm
Well, I can tell you that my Mk5 (Transit 1995-2000) used to go through a 6' 6" (~1950mm) width restriction with the mirrors being above the posts, or the drivers side folded in.
2200mm should be a doddle :P :lol:
Postby todoterreno » Mon Jul 17, 2017 1:18 am
Altransit wrote:Well, I can tell you that my Mk5 (Transit 1995-2000) used to go through a 6' 6" (~1950mm) width restriction with the mirrors being above the posts, or the drivers side folded in.
Thank u, i cannot find in the whole web a single blueprint, manual , brochure with the dimensions specs, d' you remember your MK5 width?
todoterreno
Postby ricc » Mon Jul 17, 2017 7:31 pm
just measured my mk5 2270 over the mirrors folding a mirror reduces it by about 130 mm per side
ricc
Postby gotgcoalman » Mon Jul 17, 2017 10:51 pm
depends on mirror arm length on a Mk5 .
short van type or longer tipper type.
either fold in so body width won't alter. :D
Too bloody quiet :shock:
gotgcoalman
Postby ricc » Tue Jul 18, 2017 8:45 am
gotgcoalman wrote:depends on mirror arm length on a Mk5 .
if youve got a tipper body, usually third party produced, it could be wider than the cab, they often are , then the rear body is the widest part of the vehicle , making the folded mirror width irrelevant.
i assumed we were discussing std factory van bodies. :D
ricc
Postby lerrocco » Fri Jul 21, 2017 3:55 pm
i measured my MK3 ambulance yesterday, but by myself and with the tape across the bonnet, as space was limited..
I wouldnt want to drive it through less than 2050mm with mirrors folded. I think the width is a couple of cms less than this, but 2m 5cms is a decent guide.
lerrocco
Postby Aardvark » Sat Jul 22, 2017 8:45 am
For future reference, to get an accurate width just take a piece of string with an ordinary hex nut or other small weight on the end. Hold the string at the widest point and mark the ground where the weight rests. Do the same on the other side and then measure the distance between the marks.
Learning to love rust.........
Aardvark
Postby lerrocco » Wed Jul 26, 2017 9:51 pm
i still have no access to the front of the van, but i did photograph the first page from the mark 5 (mk3-mk5) haynes book
lerrocco
