Mk5 clocks
Mk5 clocks
Postby gavcarter » Mon Jul 17, 2017 1:05 pm
Plenty of info on here using the search, however it's all scattered about and not very concise.....
I have a 2.5td 2000 build, manual pump.
Assuming I have a W feed on the alternator which Mondeo clocks can I use?
Is it Mk2 petrol or diesel?
Ideally I want a rev counter. I THINK I can swap out the fuel gauges so it reads normally.
What kids are needed to get the rpm working? Is it a simple feed from alternator or do I need to modify the Mondeo clocks?
Any help appreciated, thanks
gavcarter
Re: Mk5 clocks
Postby Aardvark » Mon Jul 17, 2017 6:30 pm
I doubt if there is a way you can tell. With mine all you have to do is fit a switch in the wire that goes between the gearbox and the speedo. The only trouble is you lose the speedo along with the odometer.
Learning to love rust.........
Aardvark
Re: Mk5 clocks
Postby wazzadj » Thu Jul 27, 2017 1:03 pm
mk2 mondeo clocks disiel or mk5 95/96 transit disiel make sure alt has 3 wire setup pin 8 on cluster plug tacho
i have a full diagram and conversion layout with wirring photos
just did mine yesterday
cheers
wazza
1994 MK4 2.5DI Auto High Roof Australian Style 1996 2.5 TDI with rebuilt AUTO Bring on the power !!!!
wazzadj
Re: Mk5 clocks
Postby Catjenkins » Tue Aug 15, 2017 2:42 pm
I have a set of transit rev counter clocks electric type whereabouts are you?
Catjenkins
Re: Mk5 clocks
Postby gavcarter » Tue Aug 15, 2017 2:43 pm
Sold van now, it was going to be a project but decided not to
gavcarter
Re: Mk5 clocks
Postby Catjenkins » Tue Aug 15, 2017 2:46 pm
ok
Catjenkins
Re: Mk5 clocks
Postby vanfox » Tue Aug 15, 2017 3:48 pm
Has there ever been a rev counter dash with a cable, not electric, speedo?
Alternatively, has anyone got an electric speedo drive unit, the bit in the gearbox, on the shelf and £?.
vanfox
Re: Mk5 clocks
Postby Altransit » Tue Aug 15, 2017 3:59 pm
There is a Mk5 one with rev counter, and a cable driven speedo, I have one somewhere that I never fitted to my Mk5 :oops: :P
I think that the early non-digital Mk6 clocks were the same, but that may be just hearsay :mrgreen:
Re: Mk5 clocks
Postby ned » Tue Aug 15, 2017 6:34 pm
Altransit wrote:There is a Mk5 one with rev counter, and a cable driven speedo, I have one somewhere that I never fitted to my Mk5 :oops: :P
Yes early mk6 clocks are analogy and the same as mk5, I think, best pic I have. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
