eresseraca wrote:Thanks Jack for the idea, I had a set of DRL on the shelf but the control box provided with them only had positive and negative wires... so I ordered a new relay and wireharness for a few bucks off ebay. As you say, should be a breeze to wire up with that one, not sure though if they'll be legal here in Finland as I might need to have the possibility to run side lights completely on their own as well... might be that dimmed DRL's won't cut it when it's time for MOT. We'll see
eresseraca wrote:Thanks ricc, that's one option but means I would still need to move the lever from "zero" position to park light position each time I start and move it back down each time I stop as otherwise the beeping will keep going and one of the the park lights will be left on (emergency mode I presume).
Would be much neater to get it directly connected to the "zero" position on the light switch/lever.
eresseraca wrote:But headlights are on low beam/dipped along with the side/park lights in the 'zero' position. So on mine there's no position when the lights are off, aren't they wired this way in the UK?
