Hello, just noticed the fluid pump for my window wiper of my 1987 Transit is not working any more.
While checking the resevoir it is full, the pump does not deliver any fluid. The lines are cleaned and compressed air blown clean aswell.
When short cut the pump via the battery it does work, and spins nicely around.
Also the lights, on same wiring loom, do work fine. I can not find an fault in the wiring itself having it checked everywhere outside the dash.
Also the switch unit at the stearing colum is cleaned and the connectors are checked aswell, i can not see anything wrong with it.
When pressing the wiper butten for cleaning fluid i can see Inside the mainswitch an copper plate pressing on to 2 small black pieces of carbon/coal connector seats ???
I can not see any metal on these seats making the connection to the copper plate from the pressing button at the top of the lever. Is there some metal missing of the seats or are these seats made from pure carbon/coal.
How can i short wire everything getting the pump working again whitout getting my dash out and making an new wiring loom.......
Please advice
