Another electrical upgrade question
My van has a heated drivers seat. I've installed an aftermarket heated seat kit for the passenger double bench, it came with it's own wire harness and relay. I've got it all wired up and switch fitted into the dash, but I'm missing a good ACC power source for the positive wire.
It already has a 15A fuse on it, I presume that it will draw quite a bit of current so I can really tap the ACC on the back of the stereo for this one, as that's already tapped for a few other extras. The 12V socket was one idea, but that one is wired to work even without the key in the ignition so won't work.
I fitted the switch for the aftermarket heated seats in a blank switch, next to the stock seat warmer switch. The blank had an unused connector from the wiring loom fastened to it on the back. I presume this one would have been used for the second seat warmer if fitted from factory.
Could I maybe tap one of the wires that goes to this connector to get a ignition switched positive?
Thanks in advance for any help on this!
