vanfox wrote:Start up and bleed the injectors, one at a time, good spurt of fuel, 17mm spanner. Change the fuel filter, all should be well.
Teeshirt.
vanfox wrote:The 34 ICH goes quite well, as does a properly set up VV, teeshirt etc.
vanfox wrote:Which ever way you go FFS carry two spare fuel filters 'cos the veg will drag all the sh1t out of your fuel tank which will manifest itself by a loss of power as the filter clogs. Stop as soon as you feel it. Make sure you know how to change it correctly at the road side and fill the new filter with diesel. Teeshirt etc.
vanfox wrote:Go easy on the easystart, a good battery and a whiff should be all you need. (teeshirt).
vanfox wrote:They are LEDs incorporated in the electronics, not interchangeable with bulbs, plus different mounting. Teeshirt.
vanfox wrote:My money is on corroded battery leads. Been there, teeshirt etc.
