Aardvark wrote:I was thinking of trying that approach a while ago and ordered a straight connector online. When it arrived it had such a tiny bore I was concerned that it wouldn't flow as much as the rubber return hose so I never tried to use it. Knowing nothing about injection I didn't know if there is much flow or just a trickle.
Aardvark wrote:I'm still trying to work out how to get the damned plastic connectors to undo. The ones I can actually see are on the top of the fuel filter housing. Two little bumps that feel a little bit loose. Tried squeezing them together and pulling at the pipe but no go. Tried twisting like a bayonet fitting but no go. Trying some Googling but no luck yet. I'm confident that if I'm to heavy handed and break the fittings its game over for weeks until I can get replacements sent from UK.
Aardvark wrote:Thanks for the input, mate. "the leak off pipes return excess fuel from the injector to the tank".
OK, sounds right. The injectors are fed with more fuel than they actually need and pass on the excess to the tank. A valve in the injector controls the point when the bypass begins. So a faulty injector/valve could cause the malfunction you describe. A spare injector (of the right type) would be dead handy for troubleshooting. Your second idea about sucking up air from an empty tank is unlikely. I always go for a full top-up when I get just below the quarter tank. I can't see any leaks between the tank and the filter housing.
As regards getting at the tee piece at the back of the rocker cover your idea might be worth a try. How do the connectors at the fuel filter top actually disconnect, and the connections to the tee piece?
fordrs726 wrote:had same problems with 2 smileys put new injectors in problems gone tried the leak of mod did not work on mine only new injectors worked still got the 2 smileys no problems since 3 years ago
gotgcoalman wrote:Without reading back.
Are the leak off pipes sealing?
old ones tend to become brittle and no provide a decent seal.
Air could be caused by that and it's an easy diagnosis/fix.
