V184 wrote:you can run di s without a fan & there normally ok, would check water pump 1st
chuck a rad on it leave thermostat out & add a bit of bleachjaycey001 wrote:Hello
My van has been overheating a bit on hills and after flushing the rad and taking the thermostat out and it still overheating I took it to a local mechanic.
The mechanic has quoted over 1000 euro to replace the head gasket and radiator (which seems a stupidly high price??)
So I am not having the work done and will stick some steel seal in and drive back to the UK.
Out of interest how many hours labour does it take to do the early 2.5Di (1989) head gasket and what price would I expect to pay to have the HG replaced?
I may shop around down here if the miracle cure doesn't work?
Cheers
