Brake disks
Brake disks
Postby Robblucky » Tue Aug 08, 2017 10:16 pm
I have a 1996 transit smiley ambulance that I'm coverting into small motorhome. Ive been in 2 motor shops today pricing front disks for 6 stud front wheels!!! both shops say impossible they must be 5 stud went through all there books and computer and can't find disks so I went back home to check in case I was wrong but they are 6 stud any ideas folks?
Robblucky
Re: Brake disks
Postby AndyG » Wed Aug 09, 2017 12:13 am
Forget trying to buy from using the amount of studs :!:
You need either Transit 150 or 190 front discs.
254mm is for 14" wheels. - NOT for you.
You need 270mm for 15" wheels :)
Re: Brake disks
Postby F111ORY » Wed Aug 09, 2017 12:48 am
I think the shops were confused as whether wheels are 5 or 6 stud, the discs are held to the hub by 5 bolts!
F111ORY
Re: Brake disks
Postby AndyG » Wed Aug 09, 2017 12:50 am
F111ORY wrote:I think the shops were confused as whether wheels are 5 or 6 stud, the discs are held to the hub by 5 bolts!
Spot on :!:
Re: Brake disks
Postby Robblucky » Thu Aug 10, 2017 10:26 am
Thanks folks I think that might have clarified the matter I'll go back to the shops now..... much appreciated the advice.
Robblucky
Re: Brake disks
Postby MinorMatt » Thu Aug 10, 2017 9:27 pm
Funnily enough... someone on facebook had exactly the same problem last week.
Just ask for discs for 15" wheels and they will give you the right ones
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Brake disks
Postby Mr RVM » Fri Aug 11, 2017 12:02 am
Robblucky wrote:I have a 1996 transit smiley ambulance that I'm coverting into small motorhome. Ive been in 2 motor shops today pricing front disks for 6 stud front wheels!!! both shops say impossible they must be 5 stud went through all there books and computer and can't find disks so I went back home to check in case I was wrong but they are 6 stud any ideas folks?
Whereabouts are you ?.....I have plenty of new ones £30 a pair......too heavy to economally post but if you can pick them up or call into TRANSITMANIA (end of Sept) ??? Have pads too....and lots of other brakes/suspension parts (all new).....
Mr RVM
