lean running transit
Postby pingu-nz » Sat Aug 12, 2017 10:29 pm
Hi there
I have a 1996 transit with a 2lt 8v petrol engine.
I have rebuilt the engine after a cracked head issue and now it runs lean when at operating temp.
It has a stumble off idle and under load after slowing and accelerating away at temp.
Runs great until temp comes up
egr removed and blanked off
Van dosnt seem to have a engine light, and the only code it has ever shown was oxygen sensor (blown fuse)
I have replaced
maf sensor
iat sensor
coolant sensor
ecu temp sensor
fuel filter
fuel pump
oxygen sensor
checked timing
Currently i have disconnected the iat sensor and it seems to run cooler with more power.
running out of options :roll:
cheers
Paul
pingu-nz
Re: lean running transit
Postby pingu-nz » Fri Sep 08, 2017 8:04 pm
got it fixed
$180 later and a bit of live data
new plug leads and problem gone
pingu-nz
Postby sportscott » Sun Sep 24, 2017 1:49 pm
pingu-nz wrote:got it fixed
I've changed loads of bits and had loads of problems with my Van and the cause was the same as yours, a broken HT lead, the back one on number 4 cylinder.
Should have been the first thing I checked :(
Transit the everyday mans van....
sportscott
