gotgcoalman wrote:not sure about the TD.
but on the di the main earth strap is held by 1 of the starter bolts.
when you changed the starter you did re connect the earth didn't you.
Altransit wrote:If it is 1998, then it will be a Lucas EPIC system, and there's nothing you can bypass with these, you need to find the fault, which the check light is showing that you have.
You should also have a red (flashing) LED in the dash to show the status of the PATS system. It will flash slowly when at rest to show that PATS is enabled. It should go solid when you turn on the ignition, and then go out if all is well
AndyG wrote:When was the timing belt last changed
