Epic to bish pump
Epic to bish pump
Postby darren.moss.355 » Sun Aug 13, 2017 3:52 pm
Hello all I no there's loads off post on here about this but am looking for quick answers. Does the 146 pump fit all engines I have a 92 2.5t. Is there any thing else other than the pump and pedal I will need. will I need new injectors or can I use the ones all ready in there? Can you modifie the epic pedal or will I need a new one.
Thank you.
Sent from my SM-N910F using Tapatalk
darren.moss.355
Re: Epic to bish pump
Postby joinerman » Sun Aug 13, 2017 6:55 pm
You will need a pedal a cable & do the water pump & cam belt at the same time
joinerman
Postby derv23 » Sun Aug 13, 2017 7:53 pm
Make sure you get the pump bracket along with said pump. I think Metal fuel lines to injectors also.
MK5 Tourneo.
derv23
