Mk4 steering fault
Mk4 steering fault
Postby jodder » Tue Aug 22, 2017 11:09 am
Hi folks, l have the transit bus auto 92, 2.0 pinto.
I have just fitted a re- con steering rack to it, everything's in the right place, fresh fluid etc.
It feels like van should feel that has no power steering as standard, so really quite tight.
Has anybody else out there had this ? Or have l picked the only dud in town ?
Thanks in advance.
jodder
Re: Mk4 steering fault
Postby twin wheel camper » Tue Aug 22, 2017 11:18 am
Is the belt tight :?: I know on the diesel transits it's hard to get it tight enough to not slip.
Is the pump working as it should :?: could be worn out.
twin wheel camper
Postby jodder » Tue Aug 22, 2017 12:44 pm
Thanks for reply, yes all ok and working well.
jodder
Postby MinorMatt » Tue Aug 22, 2017 6:04 pm
Jack the front up... engine off is it still tight?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby dumper » Tue Aug 22, 2017 7:23 pm
Also with it jacked up and engine running have you worked it lock to lock to bleed the air out the system also it is not unheard or for recon parts not to be done right I have seen recon racks that all they have done to them is put new gaters and a coat of paint straight out of a breakers yard hope you have a good one
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby jodder » Thu Aug 24, 2017 12:12 am
Yes done all that, pumps very good, have sounded off to suppliers, another on way, looks like last Sat morn was a practice run then. :cry:
jodder
