ABA wrote:sounds like accelerator pedal it don't run with a cable it is electricle contacts that wear drives normal but when you take your foot of the accelerator pedal revs stay high cost of new one from fords about £ 140
ABA wrote:just had a look on ebay there are a couple on there very cheep
DodgeRover wrote:I wouldn't get too hung up on the fault codes, I think the epic will store a lot of codes but only go into LHM if a serious fault is present on startup or whilst running, so you wouldn't be stuck in limp if you fix what is causing it but don't have the codes cleared.
