Hi Guys.
I have trouble with my battery, I replaced it last year but assumed my kids killed it charging phones and leaving lights on. I replaced it yesterday and the new one already seems to be loosing starting power. No one has left anything on this time and the battery is supposedly better quality than the last
Anyways for the last year I have been charging my battery around every two or 3 days. I had to bite the bullet and get a new one because if I drive at night I can not have lights on for long.
I think the Alternator is working but not sure how to test that. I see the voltage rise a bit when its running I will check again when the vans home. But what voltage do I expect for healthy alternator. is it possible to blow a phase or have it part working.
Is there anything else I should check. I was thinking of trying to brake the battery wire, insert amp meter, with the key out and check for excessive Amps that might be draining over night. What kind of idle current do I expect.
The new battery this time advised to me in store 130euros Bateria VARTA E38 Silver Dynamic 74 Ah - 750 A
