My 97 2.5 turbo diesel with epic system is going into LHM only after driving for half an hour or so. Restart the engine and it will be fine from take off but will revert back to LHM shortly after. Again this is only once i've been driving for a while, i guess when the engine heats up a bit? Runs well before then.
I had my epic pump fixed a few months ago, refitted and timed it myself, has been fine since then. is it possible that the timing may have slipped out since then? or is there something that could trigger LHM only when the vehicle is hot?
Thanks!
