hi everyone from Slovenija
i have a transit mk5 rimor camper year 1998 engine tipe 4EB in witch the engine died (broken crankshaft and cilinder block) I would like to change the engine but a 4EB engine I don't get in slo.
i can get a 4EC,4EA,4GD,4HA or 4HD engine. I would like to nov the diference between those engines, are all the same basic and is the diference only in
inj. pump (lucas, bosch) ECU's, manifolds and turbo or is the diference in comp.ratio, pistons ,crankshaft, cilinder head and other internals too.
i would like to take a 4EC or 4GD and take all other parts from my engine (manifolds, ECU, turbo, LUCAS pump) and other parts if the 4EC or 4GD have the same internal
parts.
Thank you for answer's
best regards from Slovenija
