How the hell could this happened
Postby mk5 rimor camp. » Sun Sep 17, 2017 4:46 pm
Hi guys
Anyone saw something like that :shock: (mk5 4EB engine)
So much about bulletproof engine :x
mk5 rimor camp.
Re: How the hell could this happened
Postby Mk5swbhighroof » Sun Sep 17, 2017 5:46 pm
Ouch.
Oil problem? Hydraulic lock?
Mk5swbhighroof
Postby MinorMatt » Mon Sep 18, 2017 12:39 pm
How on earth did you manage that???
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Trannygrandad » Mon Sep 18, 2017 8:14 pm
Did it get stuck in flood water? Water backing up exhaust can seriously damage the health
of your engine!!
Don,with fond (&other) memories of Transits from 1st pickup wayback when there were no motorways
Fave '73 with 3lt V6 , overdrive & sawn off Luton & 16ft box trailer,oh & twin fuel tanks. Exeter to Scotland return trip without refuelling,
Trannygrandad
whoops edit for double take!!
Trannygrandad
Postby mk5 rimor camp. » Mon Sep 18, 2017 8:27 pm
I bought a camper with a engine defect, the previous owner said that the crankshaft is probably broken.
I already prepared in advance that it would probably be necessary to replace the engine.
I said to myself, let's put the engine apart and see. then a :shock: what the hell?
How the previous owner did this i don't now, I have not seen anything like this before.
mk5 rimor camp.
Postby mk5 rimor camp. » Mon Sep 18, 2017 8:42 pm
When I took of cylinder head the cylinders were dry ( no trace of water) so I do not think water is the cause
mk5 rimor camp.
Postby dumper » Mon Sep 18, 2017 9:39 pm
My mate also did that to his campervan it was on a van he brought from work it had a genuine Ford exchange engine in it and not done mega miles on it only about 65000 mls he used to slog it in high gears just plodding about he never really wound it up that may have been the fault you have
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby bobbari123 » Tue Sep 19, 2017 9:44 am
Maybe too much easy start spray?
bobbari123
Postby Mk5swbhighroof » Tue Sep 19, 2017 3:13 pm
Well, a conrod bend like that, means that either the piston or the crank, suddenly stopped. Usually the piston, either through a hydraulic lock or a dropped valve, but as you rule both of those out, my money would be on a blocked oil passage, starving the big end or crank bearing of oil?
Mk5swbhighroof
Postby gotgcoalman » Tue Sep 19, 2017 6:42 pm
crank journals appear intact with no obvious scoring and have a thin film of oil.
don't know what the shells looked like though.
Bent con rod is...........
hydra lock or it's fired on the cylinder whilst the piston was on mid upstroke for whatever reason.
Wanging a load of sniff and go (as mentioned) can lock an engine up.
Timing way out or water/oil ingress into the cylinders.
Water wouldn't necesserally be present in the cylinders (depending on piston ring condition)
Too bloody quiet :shock:
gotgcoalman
Postby bambi mk 1 » Tue Sep 19, 2017 6:51 pm
I seen a few around 91 to 94 that had broken the main bearing bolts and wrecked the block but didnt break the shaft.Maybe this one was drove on :wink:
bambi mk 1
Postby mk5 rimor camp. » Tue Sep 19, 2017 7:49 pm
Bambi mk1 I think you're right, broken bolts of the first and second main bearing
mk5 rimor camp.
Postby Fastfish » Tue Oct 17, 2017 7:37 pm
Looks like somebody either forgot to tighten or over tightened them main ends imo ouchhhhhhh :evil:
Fastfish
Postby ceurieusneus » Wed Oct 18, 2017 4:37 pm
Just my idea...
The crankshaft could be broken due metal fatigue stress vibrations...
Ones the crankshaft separated in two, the shaft has pushed / slammed the piston against the cilinder head.
Doing this, it could has bended the connecting rod and breaking the crankshaft bearing bolts.
I have sailed on a tug boat, where the crankshaft had been broken and after woods welded back together!! :mrgreen:
Needless to say that engine was a pain in...(You know where) :mrgreen:
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
