Unknown Dash Light on 2000 model Tranist
Postby Kyzza » Wed Sep 20, 2017 7:09 am
Hey guys,
This light pops up on my dash occasionally for a second or so at a time, I'm not quite sure what it means as I don't have an owners manual... thanks in advance for your help!
Proud owner of multiple transits!
Campervan: 2000 Transit VG MK5 - 2.5 Di -85ps - Auto - LWB
Cab Chassis: 1999 Transit VG Mk5 - 2.5 Di - 100ps - Manual - LWB
"Spare Parts Van" 1997 Transit VG Mk5 - 2.5 Di - 100ps - Manual - SWB
Kyzza
Re: Unknown Dash Light on 2000 model Tranist
Postby twin wheel camper » Wed Sep 20, 2017 9:13 am
Looks like a coolant level low but a mk5 doent have a level indictor that I've ever seen, maybe it's a mk6 transit you have and you put this in the wrong section :idea:
twin wheel camper
Postby bobbari123 » Wed Sep 20, 2017 9:33 am
try to drain water from fuel filter.
bobbari123
Postby Kyzza » Wed Sep 20, 2017 10:16 am
twin wheel camper wrote:Looks like a coolant level low but a mk5 doent have a level indictor that I've ever seen, maybe it's a mk6 transit you have and you put this in the wrong section :idea:
That was one of my thoughts but the coolant level is a little above max so I don't think it could be :/
Kyzza
bobbari123 wrote:try to drain water from fuel filter.
I'll give it a go, thanks! :)
Kyzza
Postby dumper » Wed Sep 20, 2017 10:21 am
Or maybe washer bottle level
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby gotgcoalman » Wed Sep 20, 2017 4:06 pm
where's the pic?
as mentioned there's no low coolant sensor....so it's not that.
low brake fluid is the handbrake light.
washer bottle has no sensor.
is there a wire going to the fuel filter?
even if there isn't the wiring for it is in the loom and might have got damp.
If it's yellow with 2 or 3 wavey lines it's the WIF light.
Water in fuel.
Too bloody quiet :shock:
gotgcoalman
Postby ned » Wed Sep 20, 2017 5:02 pm
gotgcoalman wrote:where's the pic?
Water in fuel.
The picture is coming through loud and clear on my phone, over.
It looks like a Gerry can with wavy line in it, over.
Do you copy me, over.
N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bambi mk 1 » Wed Sep 20, 2017 5:15 pm
Water in fuel.
N
That light is on mk6 tdci's Ned ,its tells you to get a can of petrol and a box of matches :) :mrgreen: Joking aside as gcmsays its the wires down under the fuel filter rubbing off the starter :wink: OP check you have brake and reverse lights as it can blow the fuse :idea:
bambi mk 1
Postby gotgcoalman » Wed Sep 20, 2017 5:46 pm
I get this on phone and error 404 file not found on the PC.Image
Sent from my Plus E using Tapatalk
gotgcoalman
