I put my van back together and it won't start. New starter. found I had not plugged the pats back in. I have been checking and checking finding little things. Biggest was the oil pressure switch left unplugged. Still not starting.
Mk5 SWB 120 1999 Petrol. I have taken the lpg out. Lots of cables, worried that I may have taken the wrong wire out.
It turns over very strong, but will not start. Called AA fuel rail is full and electrics working. He checked ecu all seems like it should fire, AA is stumped.
The pats is blinking as usual. Turn key and light stays red for three seconds then off.
Dash lights up with the battery symbol and oil can.
Checked fuses seem ok.
Any ideas welcome!
