The end is in sight, to be honest I was getting a bit sick of it all, All I need do now is put in some sealer around the panel joints and finish the rear lower quarter panel, I've run out of filler but can do that with side door on and it's all behind the plastic bumber cap, plus a little bit of touching up around the filler cap and a couple of other places but nothing major for now. I've seen another rot spot under the drivers door at the bottom of the B post, nothing major that a patch wouldn't sort out but I will do that next year and do it all the sill and wheel arch, might rip it all off wing included as would rather paint than spend weeks welding:wink:
A tip I would give anybody if you are going to plug weld the sills, do it from the back, I figured it out after doing the sill under the side door
it will look much nicer.
The Job is not perfect, but needed to keep telling myself it's a 20 year old Transit ffs
But I don't think the rust will bother me again for few years on the nearside. I used heavily zinced steel for the inner sill valance, copius amounts of Tectyl ML 550 and two componet epoxy anti corrosion primer, but will be in Norway all winter so will see how it copes with the salt.
Transit the everyday mans van....
