Mk5 headlight lighting up dull
Postby Lynch807 » Wed Oct 04, 2017 7:11 pm
Hi, as with all mk5s when I have my van running with the side lights on there is a dull glow in.the headlight. This as a result sends power to the switch on the relay for the spot lights.. is there any way around this?
Lynch807
Re: Mk5 headlight lighting up dull
Postby twin wheel camper » Wed Oct 04, 2017 10:18 pm
This is called dim dip it’s the dip beam on at reduced brightness,
I think you just need to remove a relay to disable it.
It’s accually very handy but Surely your spot lights are wired up to come on with main beam not dip deam :?:
twin wheel camper
Postby Lynch807 » Wed Oct 04, 2017 11:25 pm
Yes the spots are on the heads, but because the head light bulb lights up then it switches the relay on! Any idea what relay?
Lynch807
Users browsing this forum: wardus212
