Spongy brakes.
Spongy brakes.
Postby Mk5swbhighroof » Thu Nov 02, 2017 11:18 pm
A bit odd. My brakes feel a bit spongy in use, pumping the pedal whilst breaking having very little effect. When stationary however (with the engine running, the booster is working) pumping the brake pedal twice, makes the pedal rock hard, and the brakes much more responsive (when rolling off the hand brake) The brakes work ok, and there is no loss of fluid from the reservoir, and no leaks that I can find.
Thoughts? What have I overlooked?
Mk5swbhighroof
Re: Spongy brakes.
Postby gotgcoalman » Thu Nov 02, 2017 11:51 pm
Few ideas...........
Rear self adjusters not working (slave cylinder having to push further than normal)
Fluid has absorbed water.
Fluid is blackish when cracking a bleed nipple (been over heated or has contamination from a failing flex pipe)
load sensing valve sticking.
I might think of more over night.
Servo is fed from the oil pump on the back of the alternator and if that failed it would make the brake very hard with vastly reduced brake effect.
Too bloody quiet :shock:
gotgcoalman
Re: Spongy brakes.
Postby Mk5swbhighroof » Fri Nov 03, 2017 10:22 am
Thanks coalman. I don't think it's the adjusters, because I had those out and cleaned when I changed the brake shoes recently. I'll check the fluid, to be honest, it may be a good idea to change the fluid anyway. What is baffling me is the difference in the feel of the pedal when stationary (but with engine running) versus when underway.
Mk5swbhighroof
Re: Spongy brakes.
Postby V184 » Fri Nov 03, 2017 12:29 pm
is there a difference with the handbrake on ?
V184
Re: Spongy brakes.
Postby MinorMatt » Fri Nov 03, 2017 2:59 pm
Play in wheel bearings?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Spongy brakes.
Postby joinerman » Fri Nov 03, 2017 7:33 pm
M\y first thought as well Matt
joinerman
Re: Spongy brakes.
Postby gotgcoalman » Fri Nov 03, 2017 10:32 pm
brakes being good when stationary (hanbrake applied) made me think it was a rear brake issue.
Wheelbearing causing brake fade should be felt through the pedal surely?(abs feeling on a non abs system)
1 or more flexi pipes buldging under pressure also might be something to consider.
gotgcoalman
Re: Spongy brakes.
Postby vanfox » Sat Nov 04, 2017 3:48 pm
Buy a pair of brake hose clamps, ebay, cheap, and close off a brake / axle in turn till you find a difference. Could just be all your rubber hoses need replacing.
How long should brake hoses last?
How many 15 yrs old vans are still on the original pipes and discs?
vanfox
