Broken Exhaust manifold bolts.
Re: Broken Exhaust manifold bolts.
Postby ceurieusneus » Sun Nov 12, 2017 9:50 am
If you have 10 mm bolt outside the block, I would go for welding a nut on it to.
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby therigsmith » Sun Nov 12, 2017 11:01 am
I only have a stick welder. and little experance
There is also a problem also. My electrics comes from a neighbors house with over 150m of normal cable. I had thought I was crap at welding until I tried it at a friends house and it worked so much better.
I have though blob welded a few things here some of which broke.
therigsmith
Postby Keef » Sun Nov 12, 2017 12:03 pm
If the manifold is off, take it to your local small garage or engineer. They can't charge much to weld a nut on and if it fails they may have another idea.
Keef
Postby V184 » Wed Nov 15, 2017 3:47 pm
Jim Archer wrote:If you have to drill them, be careful, as the bolts are somewhat harder than the block casting and it's easy to have the drill wander.
Jim
i think snapon or bluepoint easyouts used to come with a guide ? which stopped you going off course when drilling. If its a di there bolts not studs with the exception of the early turbo which i think had one stud on number 4 cyl ?
V184
