immobilizer and engine swap
Postby therigsmith » Thu Nov 16, 2017 1:45 am
Right goner stick a UK engine in a Portuguese van.
Portuguese 9 seater van seems to not have immobilizer. Not sure where the key and ignition stuff for the UK van is.
Is my PT van bypassed or built without. How will I go about the swap.
therigsmith
Re: immobilizer and engine swap
Postby V184 » Thu Nov 16, 2017 9:50 am
if its a late engine there's an immobilizer on the back of the fuel pump which can be removed, if yours is a turbo engine i would swap the fuel pump over from yours
V184
Postby therigsmith » Thu Nov 16, 2017 1:06 pm
Cool stuff. I can see now where my Portuguse transits pump has been messed about with an angle grinder and few crimp connectors hehe. Just copy that to my UK engine and boom.
therigsmith
Postby MinorMatt » Thu Nov 16, 2017 9:53 pm
If its a non turbo as said you may need to remove immob module from the back of the pump.
If they are both a Lucas EPIC turbo then just bolt the engine in with the pump.
Some portugese turbo transits have a factory bosch injection pump (a 154 pump) - if you have this fit to the new engine.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
