Timing hole bolts broken
Postby therigsmith » Sat Nov 18, 2017 1:03 pm
just got the new engine in. Now got to remove the flywheel I just swapped to get the timing hole out.
Somewhere along the line timing hole bolts got broken. I cannot think of when I would have put anything in this to brake it. nore dose the flywheel have marks on the back of it. Can only assume its been hit in transit.
If i cannot get the bolts out to refit is there another way to time up the flywheel if the hole is missing.
therigsmith
Re: Timing hole bolts broken
Postby vanfox » Sat Nov 18, 2017 1:33 pm
Pictures please. The flywheel timing hole is just that, a hole. No bolts fitted. Do you mean the flywheel to crankshaft flange bolts?
vanfox
Postby gotgcoalman » Sat Nov 18, 2017 4:49 pm
is it the dowel/locating pin that's snapped?
Too bloody quiet :shock:
gotgcoalman
Postby therigsmith » Sat Nov 18, 2017 5:45 pm
Good thing it was spotted. I took it off the other engine and fitted it.
God knows how but the timing hole plate was snapped in 2 places near the bolts, it looks really strong. Its the oval flange bit with 2 bolt holes with Ford and some kind of ID code onit.
One of the bolts is tamper proof snap off type. it was kind of lose fitting to I lined it up with the old dirt marks and now hope for the best timing it. I fitted a normal bolt in the other hole with the tamper bolt.
therigsmith
Postby gotgcoalman » Sat Nov 18, 2017 7:45 pm
Is it the flywheel (gear box end)
or the injector pump pully you're refering to?
gotgcoalman
Postby therigsmith » Sat Nov 18, 2017 9:13 pm
Its the 13mm timing hole. the one above and slightly right of the starter motor.
The only way to refit it was to remove the flywheel.
therigsmith
Postby vanfox » Sun Nov 19, 2017 12:00 pm
This gets more confusing every post. Pictures please! Unless.........
vanfox
Postby MinorMatt » Tue Nov 21, 2017 2:53 pm
I know exactly what he means. The hole for the flywheel pin is in a casting which bolts to the rear of the block.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby therigsmith » Tue Nov 21, 2017 10:55 pm
Yes the cast bit. Looks like a flange from inside
Why is the bolt tamper proof.
Is that some kind of chassis number on it. or was it a calibrated position. I was worried it first it could be for clearance. I dont think my flywheel hits a normal bolt but I am having loads of trouble with the engine ;(
therigsmith
Postby MinorMatt » Fri Nov 24, 2017 10:13 am
Its just a bog standard torx normally...
I don't think its a calibrated position but is just a bolt it on item
93 L GL Minibus
Postby V184 » Fri Nov 24, 2017 11:32 am
is it a shear bolt ? it is meant to be "calibrated" but you can normally see where the old one was fitted
V184
