Hi,been ages since i posted here,basically because my smiley has been faultless except for one problem i'm now at my wits end
In the past year this will be the 3rd front wheel bearing i'm having to replace btw O/S/F
Ok 1st lot were elcheapo form evilbay,lasted 2 months,2nd lot from fords(thieving gits) after 6 mths they to ended up collapsing,ones i have in now bought from bearing brothers,i get other bearings from them for other things have done for ages so well trusted.
Yes i do know how to fit them and have tried the best ways i know,using the correct torque and the old spin/tighten/spin/slack back/tighten method,never over tighten them and have a slight/very slight play in them,well greased up but not over packed, cant see anything wrong with the hub etc,i dont mount kerbs or go off road bloody hell i'm lucky if i do 200 mile a month in it all my work is local
Can i add its only the outer race that goes never the back larger one
So guys,whats the problem as i'm stumped
