Front wheel bearings Mk5 99
Postby stalwart » Sun Nov 19, 2017 6:03 pm
Hi,been ages since i posted here,basically because my smiley has been faultless except for one problem i'm now at my wits end
In the past year this will be the 3rd front wheel bearing i'm having to replace btw O/S/F
Ok 1st lot were elcheapo form evilbay,lasted 2 months,2nd lot from fords(thieving gits) after 6 mths they to ended up collapsing,ones i have in now bought from bearing brothers,i get other bearings from them for other things have done for ages so well trusted.
Yes i do know how to fit them and have tried the best ways i know,using the correct torque and the old spin/tighten/spin/slack back/tighten method,never over tighten them and have a slight/very slight play in them,well greased up but not over packed, cant see anything wrong with the hub etc,i dont mount kerbs or go off road :lol: bloody hell i'm lucky if i do 200 mile a month in it all my work is local :D
Can i add its only the outer race that goes never the back larger one
So guys,whats the problem as i'm stumped :cry: :?:
stalwart
Re: Front wheel bearings Mk5 99
Postby Keef » Sun Nov 19, 2017 7:15 pm
There must be something wrong with the hub. Personally I'd just buy a complete secondhand hub and fit it, could save you a load of grief in the long run.
Keef
Postby dumper » Sun Nov 19, 2017 8:13 pm
Is the stub axle worn or have you not fitted new outer race every time and if new race fitted is it tight in the hub
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby stalwart » Sun Nov 19, 2017 8:26 pm
Keef wrote:There must be something wrong with the hub. Personally I'd just buy a complete secondhand hub and fit it, could save you a load of grief in the long run.
I agree keef about the hub,but unless its jumps out and slaps me around the face i cant see anything wrong which this is why its bugging me
dumper wrote:Is the stub axle worn or have you not fitted new outer race every time and if new race fitted is it tight in the hub
I've fitted the complete wheel bearing kit inner and outer
Whats fords recommended torque spec on tighten the nut i've gone by haynes
stalwart
Postby MinorMatt » Mon Nov 20, 2017 10:20 pm
There are brand new genuine knucles on ebay for £45 at the moment - couldn't hurt?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby stalwart » Tue Nov 21, 2017 6:59 am
MinorMatt wrote:There are brand new genuine knucles on ebay for £45 at the moment - couldn't hurt?
Thanks Matt,yer i'm gonna go down that route,do you have a link to that,found the £70 one,be nice to save a few quids :wink:
stalwart
Postby MinorMatt » Tue Nov 21, 2017 2:48 pm
Did you find it? One sold last night. Must admit I was tempted to buy for stock
https://rover.ebay.com/rover/0/0/0?mpre ... 2909228505
93 L GL Minibus
Postby stalwart » Tue Nov 21, 2017 6:58 pm
MinorMatt wrote:Did you find it? One sold last night. Must admit I was tempted to buy for stock
Got it,thanks fella :wink:
stalwart
Postby Jim Archer » Fri Nov 24, 2017 9:45 pm
Are you checking the adjustment after a few days?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Users browsing this forum: dumyat, Google Adsense [Bot]
