Altransit wrote:I'm pretty sure that the MT75 which bolts to the Pinto petrol engine, is different to the one which mates to the Di diesel engine.
You would probably be best to source a complete engine and box to replace yours
vanfox wrote:The 2 litre van one with a VV is 8.2 to 1 comp ratio. The EFi is 9 to 1 which make a ......difference and will run very well with a VV carb. Mine did anyway, pulled like a train. Check which diff is fitted first 'cos fitting a more powerful engine will defeat any economy drive if you're still revving at the same ....revs.
jonathanferris10011 wrote:I wanted the economy from a modern engine and asking around the banana engine doesn't do that too well. Are there any other options?
Users browsing this forum: cherniy_chack
