Mk5swbhighroof wrote:I was more thinking about fitting the spare wheel to it, and maybe some spots...
ceurieusneus wrote:Mk5swbhighroof wrote:I was more thinking about fitting the spare wheel to it, and maybe some spots...
Moving the spare wheel to the front is not such a bad idea...
Anyone tried it before?? What about the cooling radiator?
It would make room under the transit for an extra tank... water? diesel?
Please keep us informed
axxez wrote:Rear doors are also not strong enough for that, so you will need some serious construction inside the door (as I do on mine). And don't think about "a plate" unless it is made of at least 5mm steel and 4 times the size of the wheeelmount
