Mk5 axle
Mk5 axle
Postby powercrazymark » Fri Dec 15, 2017 11:29 pm
Can anyone tell me the different types of axle fitted to a mk5 and how to tell the difference. Been looking but can't seem to find definitive answers.
Thanks in advance
CRAGGS AUTOMOTIVE RECOVERY & TRANSPORT
FULLY INSURED SERVICE, BASED IN TYNE AND WEAR
email:- CRAGGSRECOVERY@GMAIL.COM mobile:- 07506508703
powercrazymark
Re: Mk5 axle
Postby Luke » Sat Dec 16, 2017 12:15 am
5 stud or 6 stud :?:
Re: Mk5 axle
Postby vanfox » Sat Dec 16, 2017 9:29 am
You could just buy the Haynes mk5 book, most will be revealed......
vanfox
Re: Mk5 axle
Postby powercrazymark » Sat Dec 16, 2017 11:01 am
5 stud
powercrazymark
Re: Mk5 axle
Postby Luke » Sat Dec 16, 2017 2:15 pm
they are pretty much all the square tube type - most are the 4.56:1 ratio and if your lucky a 4.11:1 the way to tell is either read the tag on the diff bolts or if thats rusted away or missing you have to count the turns :)
Re: Mk5 axle
Postby powercrazymark » Sat Dec 16, 2017 3:10 pm
Am not looking at ratios atm am looking at English or atlas or I think there is another like a timken but not sure which is which. Or which was fitted to mk5s
powercrazymark
Re: Mk5 axle
Postby Luke » Sat Dec 16, 2017 4:43 pm
yeah think its the timken thats the square one - its a front loading diff
i dont think the atlas was ever fitted to a mk5 5 stud :?
Re: Mk5 axle
Postby powercrazymark » Sat Dec 16, 2017 7:28 pm
Ok so it's a timken are there different models of this axle for example a timken type 42? Or what type of timken axle is it?
powercrazymark
Re: Mk5 axle
Postby Luke » Sat Dec 16, 2017 7:29 pm
there are for the other mk's but in the mk5 as far as i know they are all the same :idea:
Re: Mk5 axle
Postby BROWNYS V6 » Sat Dec 16, 2017 7:42 pm
have you looked on the chassis plate on the van, should be on there what type it is, passenger side door step.
BROWNYS V6
Re: Mk5 axle
Postby powercrazymark » Sun Dec 17, 2017 11:34 am
I've had a look and mine is a timken but how do I find out what type of timken axle it is?
powercrazymark
Re: Mk5 axle
Postby Keef » Sun Dec 17, 2017 1:56 pm
I believe it's a Timken 34 if the diff casing flange is circular and loads from the front.
Keef
