Yea thats what i was thinkin ..your lookin at £200 quid upwards for bigger injectorsF111ORY wrote:If your existing injectors are working ok then don't waste your money of bigger injectors. Just turn up the fuel on the pump, and then back off when it gets to smokey!
Yea seen this vid before ..the other thing thats bothering me is the turbo oil feed , ive tried removing the alen grub screw behind the exhaust manifold and it wont budge so reading some threads i hear you can tee into the vacuum hose for a oil feed , do,s anyone on the forum know what fittings i need to do this and what size /bore hose i should use cheers gazF111ORY wrote:This did 125hp at the dyno with standard injectors! https://www.youtube.com/watch?v=P3NRSJE7RxU
Sounds like a plan , what size oil feed hose did you use from the tee to turbo ?F111ORY wrote:Yes I removed the oil pressure switch and fitted a 1/8 bsp tee. Also I didn't swap the sump, just buy a 20mm hydraulic fitting screw it in the bottom of the oil return hose , tack weld to sump, remove return hose and finish welding and then drill hole through into sump.
Hi yea when you say turn up the fuel is this from the top of the pump or from screw at the back..clockwise or anti clockwise cheersF111ORY wrote:1/4 Bsp hydraulic hose ( rubber)
Hiya yea ive seen the allen plug behind the manifold it looks like its goin to be a pig to get out , any ideas appreciatedcherniy_chack wrote:Hi, fordmaniac .
At the top of the block of cylinders, under the head itself, there must be a plug of the oil channel going from the camshaft to the head.
It may be necessary to remove the exhaust manifold to gain access to this stub.
The plug has an internal hexagon on 5 or 6 mm.
You unscrew the plug and you get the output of the oil to lubricate the turbocharger.
The oil supply hose is standard for 2.5 liters TD.
This is the standard version of all cylinder blocks after 88 years.
In addition, all cylinder blocks have holes in the main bearings of the crankshaft to cool the pistons with oil.
I'll take a photo of the block and point to this stub.
