Help with Wiring
Help with Wiring
Postby johnrdy » Mon Jan 01, 2018 7:10 pm
Hi all,
Im really struggling finding a wiring diagram for my t reg transit recovery truck. I bought it saving it from going to the scrap yard as someone had started to break it for bit. it runs fine (direct wire to the pump solenoid) but ive got no dash lights or anything. i managed to buy/got given a wiring loom from a similar aged transit as when it was been broken for bit the cut loads of sections of the loom.
its got s seperate mini fuse box with 1 80 amp fuse and 1 60 amp fuse
its then got a seperate fuse box with a relay (yellow) then 3 standard car fuses. I cant quite figure out which wire goes onto which.
ive bought a haynes manual but non of the wire colours on any of the pages match up with what ive got. im going to take some photos tomorrow in the hope that someone can say ..... that one goes there, that one goes here
im assuming the one under the bonnet is the starter relay? with the ignition relay inside the cab with a large red wire, then opposite a large green and white wire.
Does anyone have a similar set up? could they send a few photos over?
its killing me!
thanks John
johnrdy
Re: Help with Wiring
Postby KING OF ENGLAND » Mon Jan 01, 2018 9:53 pm
Would be easier with pictures mate then I could possibly help
KING OF ENGLAND
Postby MinorMatt » Thu Jan 04, 2018 2:36 pm
There are loads if variations of looms etc
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
