Keef wrote:The very early Mk3's with the lucas CAV pump had no lift pump and no hole for it but all Bosch pumped DI's had lift pumps from factory.
The Bosch pump will run happily without a lift pump but priming the system is much more difficult.
bambi mk 1 wrote:Keef wrote:The very early Mk3's with the lucas CAV pump had no lift pump and no hole for it but all Bosch pumped DI's had lift pumps from factory.
What factory Lift pumps were fitted from 1988 on when the smaller rocker cover bolts and pencil injectors were fitted .I have seen many bosch equipped ones with no lift pump plus most late mk 2 di's had a bosch pump and no lift pump
F111ORY wrote:I believe the lift pump was introduced for the Epic. After its introduction all engines got a lift pump. The bosch pump will draw fuel from the tank once bled up.
