Front inner wing cost
Postby Crain6692 » Mon Jan 15, 2018 6:47 pm
Hi guys,Im new to the forum.Quick question as to how much all in it would generally cost to have one side of the vans front inner wings fully replaced?Ive seen this is an ancient subject though any answers are much appreciated.
Crain6692
Re: Front inner wing cost
Postby ceurieusneus » Tue Jan 16, 2018 5:49 am
Hi, about your "Quick" Question, I hope for you it will be answered many times...
For me, it razes more questions than answers...
Why the inner wing? what about the outside wing? what about the rest of the van?
How old is the van, how much is the value of the van, how is the condition af the rest of the van?
But most off all HOW MUCH RUST, outside, inside and underneath the van!!!
Even when you post pictures, this is a very difficult question.
Ones you start working, you will most of the time find more (hidden) problems. :?
I would suggest, try to find a (Transit) expert, on the forum, and let him have a look at your van first :wink:
Good luck
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby vanfox » Tue Jan 16, 2018 9:04 am
That was constructive, not! Both mine have more patches than a patched thing!
Cost will depend on, a, finding someone willing to do the job, b, how difficult it is to reach the area and c, whether you can Mig weld. Here's one, N/S inner wing, I did earlier....
Post some pics of what you think needs doing using the "upload attachment" button.
vanfox
Postby cherniy_chack » Tue Jan 16, 2018 11:45 am
vanfox wrote:Cost will depend on, a, finding someone willing to do the job, b, how difficult it is to reach the area
Crain6692,if you are going to come to Kiev, I will do it quickly and inexpensively. :D
Only $ 50 for every detail.
cherniy_chack
Postby Crain6692 » Tue Jan 16, 2018 6:21 pm
Vanfox,thank you for your sensible reply mate.Yep It pretty much looks similar to that at the minute,Im considering just taking it easy and doing it myself as I bought the van out of nostalgia :lol: As for the rest of the van etc..Ill post when I come to that bridge :D :D
Crain6692
Postby ceurieusneus » Tue Jan 16, 2018 6:35 pm
To Craine,
Why on earth do you waist my time, asking how much it will cost, if a day later you post you are doing the job jour self :x
ceurieusneus
Postby Crain6692 » Tue Jan 16, 2018 6:39 pm
Why would you bother your arse following a post that you've no decent input to son?
Crain6692
Postby Crain6692 » Tue Jan 16, 2018 6:49 pm
Just to clarify for the sake of it.First of all I havnt welded since I was in the army..second I was looking not to get ripped off hence the post and third point is that the guys on here seem to be pretty helpful.So if my question wasn't up to standard then don't comment from Belgium
Crain6692
Postby Altransit » Wed Jan 17, 2018 10:25 am
A little light reading that you may find interesting :)
:arrow: viewtopic.php?f=27&t=26443
Postby ernie b » Wed Jan 17, 2018 12:32 pm
Check out central panels website if you haven't already
Good selection of panels for the Transit and fitment usually isn't bad
If you have a major job on everything between the chassis rail and wheel arch is available
If you are competent with a mig it's doable at home
If it's like Vanfoxs pic I'd replace the outer section of the inner wing and patch the inboard section as long as the rest is sound. Have a good poke around before making a decision or ordering panels.
Either way it's best to remove the outer wing, if it's sound (doubtful on these old girls) and you're careful reuse it, if not chuck and replace
ernie b
Postby vanfox » Wed Jan 17, 2018 4:20 pm
Lots of help here. In my case I left the wing in place and plated from the good edge back to where the inner wing was still weldable. The blue stuff is Vactan rust proofer, which my vans are covered in. Proof of the pudding is they're both reg.d in 1999 and still pass MOT tests. (As do lots more on here!!)
vanfox
Postby cherniy_chack » Thu Jan 18, 2018 3:09 pm
Crain6692,hello.
On the Continent sold repair inserts arches front wings.
Should be on sale and on the Islands.
To replace the arches, you need to remove the front fenders and the arches themselves according to the size of the inserts.
Usually this is not a problem.
No problem installing the front wing repair part.
The front wing should buy a new one.
The old is usually damaged by corrosion and its repair will cost more than the new one.
cherniy_chack
Postby cherniy_chack » Thu Jan 18, 2018 3:17 pm
Remo insert the arch.
https://images.kuzov.kiev.ua/73afc991c5 ... 0986eb.jpg
Repair wing.
https://images.kuzov.kiev.ua/200245b46f ... a88efe.jpg
Two parts cost about 80 dollars in Kiev.
cherniy_chack
Postby Crain6692 » Sat Jan 20, 2018 3:58 pm
Thanks for the replies guys,very much appreciated!
Crain6692
Postby Crain6692 » Sat Jan 20, 2018 4:22 pm
On further investigation it seems that the entire inner arch needs cut out and renewed as the corrosion has weakend the strut mount etc..,the old vans worth it so it shall be done!lol :D
Crain6692
