Mk4 Pinto battery, biggest CCA that will fit?
Postby po79 » Tue Jan 30, 2018 11:27 pm
Hi guys,
My transit has never be a good starter and I remember some of my previous cars running pintos never turned over well on the standard battery.
Last time I did a an engine conversion I used a diesel battery but as that was a custom car I made the battery tray to suit.
So does anyone know what the most powerful battery I can use that will fit the standard battery tray and with the correct terminals the correct way around.
Cheers,
Poe.
po79
Re: Mk4 Pinto battery, biggest CCA that will fit?
Postby Altransit » Wed Jan 31, 2018 12:28 am
Varta E38 has a CCA of 750amps, and fits the petrol battery tray, 278mmx175mmx175mm but I don't know which side your connections are, as standard.
Positive is front right on this battery :)
Postby po79 » Thu Feb 01, 2018 9:40 pm
Thank you I will check those out, same terminal lay out however mine are square post so will see if these are available.
Cheers,
Poe.
po79
Postby Altransit » Fri Feb 02, 2018 2:56 pm
You can get post adaptors, or just change the ends, or the whole lead, for the round post :idea:
Postby Chug » Fri Feb 02, 2018 7:25 pm
You can also fit a slightly bigger battery by knocking the front and rear of the battery tray lips down flat. :wink:
Chug
