So I'll be having the service station fit new discs and brake pads sometime next month I started thinking about the front ride height at the same time.
It's quite a lot lower in the front (like the Mk5's originally are designed to from the factory). As it's a camper that doesn't carry heavy loads at all I'd like to raise the front a bit, say 4-5cm or so, to have it more even front to back and at the same time get a bit more clearance up front for parking and beach parking spots etc.
I was thinking about getting these Kilen 190 springs:
http://www.ebay.ie/itm/Kilen-Front-Coil ... 41c72b6c4cAnd have the station swap the at the same time they do the front brakes and hopefully get a bit of discount on the job as they could do it at the same time the remove brakes and replace wheel bearings.
Questions for you guys, the reg. papers says the van has a GVM 3300kg... guess that means it's a 150, right?
- how much higher will the front approx sit on 190 springs? Just want to confirm that it doesn't suddenly start to lean back instead, if the coils would raise it up 10cm or something!
- is it an easy swap for the service station? That is, a straight swap of coils only without needing to swap or buy new shocks even if the coils would be for a 190 model?
