looking to do a petrol conversion on my mk5
Postby TransitCamper » Tue Feb 06, 2018 5:37 pm
Hi i'm looking to do a petrol conversion on my mk5 what's the best engine to use? Thanks in advance
TransitCamper
Re: looking to do a petrol conversion on my mk5
Postby denagen » Tue Feb 06, 2018 7:23 pm
I own a Mk 5 with petrol engine, it's a Westfalia Nugget camper. Due to expensive corrosion damage, I'm looking to sell it. The engine is still good, purrs like a kitten and starts without a hiccup even in moist and cold conditions. It has run 203.000km.
Minor issue: I'm in the Netherlands :-)
denagen
Postby DodgeRover » Tue Feb 06, 2018 11:06 pm
2.0 pinto is simple.
2.0 Zetec is modern and you will need to sort out a loom for injection and sparks
3.0 V6 Essex is old heavy and powerful
3.5 and up rover v8 should fit
DodgeRover
Postby vanfox » Wed Feb 07, 2018 12:17 am
If you go for a Pinto SOHC try to find an EFi Pinto SOHC from a Sierra and run it on a VV. The EFi is 9-1 compression ratio, mine pulled like a steam train. A 34 ICH kit will work if set up with correct chokes and jets etc either way be sure to fit the hot air collector or you'll end up with carb. icing.
Before you install it check the cam and oil spray bar is OK, the cam comes out the back of the head, head off once installed. Check the stem oil seals as well, there's a tool to do them without lifting the head.
You'll need the engine/ MT75 gearbox adaptor plate and the transit exhaust manifold(?).
vanfox
Postby Hondekop » Wed Feb 07, 2018 1:49 pm
2.9 V6 Cologne is another alternative, preferably with the MT75 as well as ECU attached to it.
Ciao, Kai
1992 MK4 LWB van, 2.5 TD 101 HP
Hondekop
Postby cherniy_chack » Thu Feb 08, 2018 4:50 pm
TransitCamper,what motor is used now?
cherniy_chack
Postby mutus » Fri Feb 09, 2018 10:58 pm
IVE got a S reg MK5 Campervan with a 2 LT DOHC petrol done 105000 miles starts first time everytime just done 700 miles to Scotland the MOT runs out on the 28 Feb will be scrapping as the welding for mot is going to be about 6 to 7 hundred drive anywhere at the moment.any good where are you from I'm from South shields Tyne and Wear.
mutus
