Hi all, just a quickie. I need to replace the outer sills on my van (drivers & passenger side). I've bought the replacement sills and cut out the rot of the old (not a lot but needed doing) , but I've cut down the replacement panels in length as not all the sill was rotten. My question is , for the MOT can I plug weld the bottom where the inner and outer sills seam together and then seam weld the remaining sills side or does even the bottom part need to be seam welded ??
Cheers
Paul
