Well, I've tried the search function, but it's like looking for a needle in a stack of needles....
The pipe from the thermostat to the cab heater has chaffed through, and the top hose to the radiator looks like it's past its best too, so looking for replacements. Thinking of replacing other pipes whilst I'm at it. Local scrapyard has none, or doesn't want to know, and the choice online is somewhat confusing, i.e. when searching for a top hose, using the year and type of engine, different pipes come up, even from the same seller?
Can you 'make your own' from suitable radiator pipe? I have a local supplier. Is there a list of the various hose diameters on line (none in the Haynes "manual")?
Or can anybody recommend a good place to get new pipes.
