I have a 1997 2.5 Diesel Automatic Ford Transit Campervan. We've only had it a short time and I'm not a mechanic. The problem is that it's really difficult to engage reverse and drive (even when the selection indicator shows them as selected). It becomes a bit easier as the van warms up. We had an automatic specialist look at it and they say the gear cable (Ford Part 6516529) has worn and needs replacing, but also that there's sideways movement in a rod inside the gearbox case which shouldn't be so and is more serious. They say they don't work with these gearboxes anymore. Milage is only 44,000 miles.
Any advice on what we could do or where we could take it for help would be appreciated. We're in North Essex/Colchester
Thank you
