REMOVE starter motor/solenoid >>sourcing..BEST BRANDS
Postby 97transit2.5D » Thu Feb 15, 2018 1:56 am
Hi almost certain the the solenoid is either worn or the positive strap to solenoid connector is faulty.....looking at removing the said unit.
Question 1: those mounting nuts for the WHOLE starter ...how do you remove them..do you go under the van. I have a 1/2" kokIen rachet with extensions and do you use a extra length of torque bar over handle of rachet?
and how do you work...??? above engine OR UNDERNEATH?
Question 2: replacing the solenoid is easy as...are there best brand anyone can recommend...on EBAY.UK???? as well as BEST starter motor..will replace solenoid first
any posts for removing the starter???....can you put in a link...cheers and beers...Rick
PS vehicle is a 1997 ford transit smile 190 76hp 2.5 non turbo....in NEW ZEALAND
97transit2.5D
Re: REMOVE starter motor/solenoid >>sourcing..BEST BRANDS
Postby baxi » Thu Feb 15, 2018 12:36 pm
one or two bolts awkward best use a 1/2 universal socket connector with extension .
baxi
Postby 97transit2.5D » Sat Feb 17, 2018 10:29 am
hi for the lack of relies it must be easy job...but the nuts..(yes i has a 1/2 inch socket drive with extension) seems really torqued up..any previous posts on this?? have trouble getthing them undone to remove whole starter assembly
Rick
97transit2.5D
Postby cherniy_chack » Sat Feb 17, 2018 5:39 pm
First you need to disconnect the solenoid connection lead, then the power cable of the starter motor from the solenoid, then unscrew the three bolts securing the starter to the engine and take the starter out from under the bonnet.
cherniy_chack
