Power steering conversion
Postby sarmatt1 » Sat Feb 17, 2018 11:17 am
Hi.
I have 1996 swb 2.0 petrol, but non power steering.
Does anyone know if the diesel model power steering system is the same as the petrol?
I am hoping it’s maybe just a different bracket for the pump on the engine.
Any help will be greatly appreciated.
Matt
sarmatt1
Re: Power steering conversion
Postby cherniy_chack » Sat Feb 17, 2018 4:43 pm
sarmatt1,The steering rack is the same as the diesel, which is petrol.
Pumps are different.
cherniy_chack
Postby sarmatt1 » Mon Feb 19, 2018 12:49 am
Cherniy-chack, thanks for the info much appreciated.
Will look into sourcing the parts
sarmatt1
Postby dumper » Mon Feb 19, 2018 9:49 am
I have a diesel set up for sale low miles off my old camper
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby sarmatt1 » Thu Feb 22, 2018 1:43 pm
Hi dumper.
Thanks for your reply.
If it’s all working ok, how much would you like for it?
Also, I am near Gatwick for logistics side of things.
Matt
sarmatt1
Postby vanfox » Thu Feb 22, 2018 3:25 pm
Quite prepared to be corrected here, I think you will need a duplex crank pulley, unless already fitted, a pinto or DOHC pump mounting bracket plus pump, reservoir, hoses and a belt.
vanfox
Postby sarmatt1 » Thu Feb 22, 2018 10:23 pm
Hi vanfox.
Thanks for reply. I was thinking the engine bracket would probably be different to the Diesel engine.
Trouble being, the petrol vans are not too common so unfortunately I can’t just ask someone to look under their bonnet.
More research needed I think when I get time.
Matt
sarmatt1
Postby vanfox » Thu Feb 22, 2018 11:58 pm
These engines were fitted to, amongst others, the Sierra etc. Some had power steering, go look/ask around breakers. If you buy the Haynes book for the petrol transit, 1468, most all will be revealed.
vanfox
Postby sarmatt1 » Fri Feb 23, 2018 3:10 pm
Now thats a good point.
Thanks for advice, will get on with that at the weekend.
Matt
sarmatt1
Postby cherniy_chack » Fri Feb 23, 2018 7:31 pm
Two years ago, I helped my girlfrend buy and change the 2.0L petrol engine on the Transit.
We bought a motor and power steering pump from a gasoline Sierra.
The pump is exactly the same.
A transitional plate and a flywheel from the old motor were installed on the motor from the Sierra.
cherniy_chack
Postby finn_mccool » Fri Feb 23, 2018 8:04 pm
Let us know how you get on. I may need to consider power steering when this thing eventually gets back on the road.
finn_mccool
Postby MinorMatt » Fri Feb 23, 2018 9:29 pm
If you fancy a trip to Haywards Heath next time i am there you can look at a DOHC with PAS, and a diesel with PAS at the same time as yours to see whats different. I have a diesel setup spare and sitting in the back of a van too
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby vanfox » Sat Feb 24, 2018 11:33 am
As an alternative would it be possible to adapt an electric steering pump instead of using the belt driven power sucker?
Just a thought....
vanfox
