by cherniy_chack » Sun Feb 18, 2018 4:13 pm
Motor overtemperature occurs when when the motor generates excessive heat due to improper tuning or the cooling system has a malfunction.
In the first case, there is usually a large fuel consumption, in the second case there is a malfunction of the thermostat or dirt in the radiator.
You have already replaced the thermostat, but the motor overheats?
The main valve of the thermostat in boiling water should open by 8 millimeters, no less!
You can replace the radiator, use a radiator from 100 strong turbo engine or from a gasoline. They better remove heat because of the large size.
And both are in the place of the regular..
Before changing the radiator, you need to monitor fuel consumption. If it is more than 12 l / 100 km, then first you need to eliminate the cause of high fuel consumption.
