1998 Mk5 Autosleeper
Postby Danrad » Wed Feb 21, 2018 5:55 pm
Hi, I have recently bought a 1998 Mk5 Autosleeper motorhome ( 2.5 TD) and I have a couple of questions related to attached pictures. One shows a graph stuck to the passenger door step. What is it for? Please note the vehicle has additional air suspension units fitted on the back axle with a pressure gauge and air connection point in the drivers door step. The second question is what is the electrical connection near the rear of the gearbox (MT75 box). You can just see the flange of the prop shaft in the picture. It is not the reversing light switch. All responses welcome. Thank You
Danrad
Re: 1998 Mk5 Autosleeper
Postby Frag » Wed Feb 21, 2018 9:23 pm
Electrical connection on gearbox,is the vehicle speed sensor,sender for speedo..
The graph is for setting the LAV,LSV,LLV whatever you prefer to call it,it adjusts the fluid pressure to rear brakes depending on the weight on rear axle.
Supposed to stop rear brakes locking up when empty,allows more fluid pressure when loaded...
Frag
Ford Technician
Postby MinorMatt » Wed Feb 21, 2018 9:24 pm
Graph is for setting up the brake load apportioning valve... don't worry about it.
Connection is vehicle speed sensor - which runs the speedo
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Danrad » Thu Feb 22, 2018 12:22 pm
Many thanks to Frag and others for prompt and informative reply - I have learned something new. I like to understand what I am looking at.
Danrad
