MK5 Diff Ratio
MK5 Diff Ratio
Postby Pmacnz » Thu Mar 08, 2018 10:15 am
Hi Guys, just joined the forum.
Bought a 1996 VG (MK5) 2.5TD manual 5 speed about 6 months ago as a delivery van, has a tail lift so is pretty handy.
Location is Perth Australia.
Anyway the issue at hand is what RPM is normal for this vehicle at 100kph (60mph)?
Mine is running at 3200rpm @ 100kp which is not ideal in my book. It is very low geared right through the range 1st being almost useless.
What is considered normal rpm @ 100Kph? and are there a various diff ratio for this model.
Thanks in advance for all input.
PMac.
Pmacnz
Re: MK5 Diff Ratio
Postby vanfox » Thu Mar 08, 2018 3:10 pm
Go to: Mon Jan 29, 2018 7:47 pm Neils Transit all about changing diff.
vanfox
Re: MK5 Diff Ratio
Postby cherniy_chack » Thu Mar 08, 2018 4:55 pm
Pmacnz,the ratio of 4.56 for the rear axle type 34 (5 studs) or 5.14 for the axle type 53 (6 studs) is the norm.
Your engine speed matches that.
Reducer 4.63 for axis type 53 can be found, 4,10 for axis type 34-none.
cherniy_chack
Re: MK5 Diff Ratio
Postby Pmacnz » Fri Mar 09, 2018 5:34 am
Thanks guys, its a 6 stud axle so Ill be looking for a 4.63 ratio.
Pmacnz
Re: MK5 Diff Ratio
Postby cherniy_chack » Fri Mar 09, 2018 5:54 am
3200 rpm at a speed of 100 km / h?
Then at you more likely a reducer 5,83.
The gear ratio of the gearbox can be specified after decoding the sign on the passenger stage.
Section 16
Indicates the gear ratio of the rear axle by code:
B N L G J K M
3.91 4.11 4.56 4.63 5.14 5.83 4.18
http://transit-club.com/shield.gif
http://transit-club.com/sh_sield.gif
cherniy_chack
Re: MK5 Diff Ratio
Postby Pmacnz » Sat Mar 10, 2018 7:02 am
Good info thanks Cherniy
Comes up as a J = 5.14
Look like I've found a better ratio second hand diff, looking forward to some better fuel economy and doing more than 90km/hr holding up traffic.
Crazy that it has such a low ratio, Perth is flat as a pancake, you'd have to travel about 4000km to find a decent hill.
Pmacnz
Re: MK5 Diff Ratio
Postby cherniy_chack » Sat Mar 10, 2018 11:19 am
Find the axis of 4.63-great happiness.
cherniy_chack
Re: MK5 Diff Ratio
Postby wobbles » Sat Aug 04, 2018 10:44 am
did you complete this diff change ? mine is the same and was wondering what difference is
cheers
wobbles
Re: MK5 Diff Ratio
Postby rebuilder86 » Thu Aug 09, 2018 11:33 am
im also in perth, mine is a mk5 VG 1999 SWB Low Roof, and at 100 kph in 5th its about 3100-3200 RPM, but i just checked that plate on the pasenger foot well, and provided i was looking at the right section, mine is a 4.63.
Im not sure how to do the maths to work out if perhaps mine actually got a replacement diff gears of the wrong variety at some stage in its life and also had the speedo adjusted to compensate perhaps?
Its jus tan obsurd rpm to be at 100kph, and cherniey telling us what we want is 4.63, well, thats apparently what im supposed to have, and it sucks!
rebuilder86
Re: MK5 Diff Ratio
Postby gotgcoalman » Thu Aug 09, 2018 7:10 pm
My 4:63 ate itself ealier this year :(
Replacement was........4:63 :D
An "indicated 90" (140 metric) before the noise gets too much is achievable fully loaded :shock:
Spedo shows 2 mph out @ 30 acording to those speed check light up things.
Not sure at higher speeds though.We'll assume 10% or so :wink:
No rev counter so I'll guess the RPM.
LOTS :lol:
Fueling turned up and extra air added via the rocker breather and blank plug on the manifold.
Too bloody quiet :shock:
gotgcoalman
Re: MK5 Diff Ratio
Postby rebuilder86 » Fri Aug 10, 2018 2:42 am
A mate of mine, who is a genius has a program on his computer called gearcalc, and he used it to back calculate my diff ratio based on stock 5 sp manual, 100 kph, 5th gear, std tyres and we get 5.11. So if u have a 5.11 you should be at 3200 rpm at 100kph.
rebuilder86
Re: MK5 Diff Ratio
Postby twin wheel camper » Fri Aug 10, 2018 9:45 am
No genius’s needed :lol: all you need to do is jack up both rear wheels off the ground and put the van out of gear, then put a chalk mark or similar on the prop shaft and also on the tyre then turn a rear wheel and count how many times the prop shaft turns till the wheel turn 1 complete revolution, that’s it so if you have a 4.63 the prop will turn less than 5 times by the time the wheel makes a full revolution and if you have a 5.14 it will turn just past 5 turns.
twin wheel camper
Re: MK5 Diff Ratio
Postby rebuilder86 » Fri Aug 10, 2018 11:18 am
hes a genius coz he did it remotely. :P
woudlnt that methdo u describe, jsut turn the other wheel opposit direction?
i think ud need to get under the car and turn the prop shaft and do it backwards. unless u could somehow spin both wheel at the exact same time.
And even then, its liekly that one wheel woudl turn faster than the other because bearings arent perfect fluid.
rebuilder86
Re: MK5 Diff Ratio
Postby MinorMatt » Fri Aug 10, 2018 11:22 am
One wheel in the air, other on the ground. Double propshaft revs to give diff ratio.
Will be a 5.14 not a 5.11
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: MK5 Diff Ratio
Postby twin wheel camper » Fri Aug 10, 2018 11:35 am
MinorMatt wrote:One wheel in the air, other on the ground. Double propshaft revs to give diff ratio.
Matt don’t complicate things :lol: :lol:
twin wheel camper
