rear door
rear door
Postby rolo.m » Fri Mar 16, 2018 5:49 pm
I need a left rear door with window for ford transit swb80 -it is standard size ie not high top 156cm height
rolo.m
Re: rear door
Postby Chug » Sat Mar 17, 2018 12:26 pm
I may possibly have but wont be able to confirm for a couple of days as they're not here at home, I have a pair and a side door from an r reg but I cut plates out of one for welding up another van, don't think they're in too bad nick, not sure which ones are left and not sure about window but I will let ya know as soon as possible. Where abouts are you anyway?
Chug
Re: rear door
Postby rolo.m » Sat Mar 17, 2018 3:43 pm
I am in Colchester
rolo.m
Re: rear door
Postby Chug » Tue Mar 20, 2018 10:27 am
The door I cut up was the left one, sorry, but I still have the right door but it has no window.
Chug
Re: rear door
Postby vanfox » Tue Mar 20, 2018 11:19 am
Depending on the problem can you not get it repaired? Bottom repair panels are available, couple of hours work with a Mig.
Here's mine before and after. The join is behind the number plate, much easier than replacing the bottom half.
vanfox
Re: rear door
Postby rolo.m » Tue Mar 20, 2018 2:20 pm
yes I hope that is doable-thank you for that
rolo.m
