panel treatments
panel treatments
Postby enjoythistripp » Wed Mar 21, 2018 2:13 pm
ok so they must be thousands of posts regarding rust prevention and cure. Im treating my old Mk5 chassis cab/luton to a complete rebuild. That's inner and outer wings, arches and sills/step etc. I want to give them a few coats of long lasting protection before they are applied and sprayed. Im planning on hand painting or rattle cans. What would you recommend?
You can take a man out of a transit but you cant take the transit out of the man
T350 2.4 TDCi Xlwb Luton 115ps 2007
enjoythistripp
Re: panel treatments
Postby Islander71 » Wed Mar 28, 2018 1:44 pm
Have used this on my Navarra chassis - so far so good.....https://www.arc-rite.co.uk/corroless-s- ... ize-2027-p
Always think it better to use a paint brush than rattle cans - goes on much thicker.
Islander71
Postby Mr RVM » Mon Apr 09, 2018 6:50 pm
The front wings on a mk3/4/5 aren't structural so don't need to be welded on.......(it's the welded edges on the lower part where the rust starts).....so just bolt/screw/rivet them on......this allows you to coat all the mating surfaces before you fit them......(which doesn't get burned off like it does when they are welded on :wink:
Use a decent quality etch primer on any bare metal......then paint any 'behind the scenes' and mating surface
areas with a brush (as said above...."you get a thicker coat")
When you do the final fit use a bit of PU adhesive on the mating surfaces to prevent water from being 'sucked' into the joint :wink:
Mr RVM
Postby ABA » Mon Apr 09, 2018 7:05 pm
red lead or red oxide
ABA
Postby dumper » Mon Apr 09, 2018 10:04 pm
Then waxoil the underside when all paintwork dry
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Riggard » Wed Apr 11, 2018 5:31 pm
I used brantho korrux 3in1 for the invisible parts, awesome paint, very tough and works great against corrosion.
Riggard
Postby angusp » Wed Apr 11, 2018 8:58 pm
Interesting to hear the wings aren't structural so don't need welding - is this true for the arches as well?
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby fuzzedup » Thu Apr 12, 2018 8:43 am
angusp wrote:Interesting to hear the wings aren't structural so don't need welding - is this true for the arches as well?
Are there any MOT testers out there who can confirm this, as i got a front wing that needs replacing ??
fuzzedup
Postby dumper » Thu Apr 12, 2018 10:26 am
Pm Paul 2012 he seems up to speed on new mot rules I never had a problem with my mk6 escort when I bolted the front wings on it but time change you could aways have a word with your local tester who tears your van
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
cron
