Attachment of the heater flap control panel
Postby Kjeles » Sat Mar 24, 2018 9:08 am
According to Haynes, the heater flap control panel in an Mk3 is attached only by two nuts at the upper front. However, two holes at the rear part of the flap control (photo) suggest that the panel should be attached to the heater unit too somehow. Or do these holes serve no function?
Kjeles
Re: Attachment of the heater flap control panel
Postby Kjeles » Mon Mar 26, 2018 12:01 pm
To answer my own question:
It doesn't look like the two parts are supposed to be joined by a bolt. However, after mounting the heater unit and the flap control panel, the two holes (white arrows) lined up with the lower of the two holes in the heater unit (shown by yellow arrow [the upper hole is not visible on photo]). So why not bolt them together and make the panel more sturdy?
To bolt the two parts together, I had to make a 19 mm spacer for the right side and a 9 mm spacing for the left side.
The spacers look like this.
Kjeles
