Very Early Turbo Di with Bosch pump?
Postby vanfox » Wed Apr 04, 2018 11:30 pm
If this is complete b******s ignore it.....I seem to recall the very early turbo Dis had a bosch pump. How was the EGR, if fitted, activated? I keep seeing stuff in the press about tougher MOT tests, all the EGR stuff must be present, tougher smoke test etc. Again, if this don't apply to Smileys all so well and good but does anyone have a definite answer.
It also seems a failure will cancel out any remaining time left on your MOT, you won't be able to legally drive home and the feds will be waiting for you if you do. I think this has been mentioned before, again comments?
vanfox
Re: Very Early Turbo Di with Bosch pump?
Postby F111ORY » Wed Apr 04, 2018 11:39 pm
Hi, I understood Turobs with Bosch pump were sold outside of the EU.
F111ORY
Postby MinorMatt » Thu Apr 05, 2018 7:57 am
The really early ones didn't have egr.
Plus EGR will not be inspected on pre 2009ish vehicles (in fact the test manual only mentions EGR on petrols
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby cherniy_chack » Thu Apr 05, 2018 2:57 pm
F111ORY wrote:Hi, I understood Turobs with Bosch pump were sold outside of the EU.
The turbochargers with Bosch injection pump were produced for Turkey.
cherniy_chack
Postby V184 » Thu Apr 05, 2018 9:12 pm
There was a few in the uk, think they also fitted them to taxis ?
V184
Postby mrepson » Mon Apr 09, 2018 1:39 pm
is this the very very first 2.5di ford made, :?: as it has the very early big,cav injectors like a mk1 York transit, :?:it has all genuine ford pipe work,with a bigger garrett turbo on a 4 bolt flange manifold,has ford casted on the manifold,i have never seen one before,has a bosch manual pump,& also has a breather pipe from the sump to the rocker cover,all looks factory,all the other smiley turbo transits I have had always have a smaller kkk turbo fitted with different manifolds :?:
mrepson
Postby V184 » Mon Apr 09, 2018 2:20 pm
Yes that looks like it, was based on the early di as you say its got the 2 bolt injectors 8)
V184
Postby F111ORY » Tue Apr 10, 2018 12:19 am
Hi, What is the pump number?
F111ORY
Postby mrepson » Tue Apr 10, 2018 8:29 pm
its very hard to see the number,as it has a alloy block bolted on with a lot of thin pipes,covering the numbers, there is no vac pipe from top of pump to inlet manifold :?:
mrepson
Postby V184 » Tue Apr 10, 2018 10:29 pm
F111ORY wrote:Hi, What is the pump number?
i think it was the same pump as fitted to the early non turbo engine Bosch with the cable from the thermo wax stat (which is broken in the photo)
V184
Postby mrepson » Wed Apr 11, 2018 1:14 pm
yes shakes,ticks over very low until get warmed up,so are these early cav injectors better,can you get bigger, or are the later smiley heads with 100ps brown spot bigger, ie more poke :?:
mrepson
Postby V184 » Wed Apr 11, 2018 1:39 pm
Think the pistons are different in the early engines ?
V184
Postby Hellblazzer » Sat Apr 14, 2018 3:06 pm
I think this is relative to that picture's engine:
http://www.fordopedia.org/parts-catalog ... mk3/Z7.697
-1986 Mk3 2.5di 80ps banana engine and some more mods-
Hellblazzer
